4G on the Antenna
jhunterwu
Bergen, Norway
I need 4G router in the car and want to use an antenna on the outside of the vehicle to get better reception, as I use the vehicle in quite a few places without good LTE coverage.
Short of drilling a hole, can I use the existing socket in the back of the roof?
What is the connector on each end called?
I will forego using radio, as 4G is more important to me.
You’d be better off leaving the wiring alone & just running the antenna cable through the door seals, however I doubt you’re going to get any more gain by using a different antenna to the one installed in the car.
Does the hotspot facility not work for you?
Get a good window antenna.
One that can be stickied to the inside of the window, and is made for 4G
The extra gain from installing an outside whip, would be marginal, i would argue that if the signal is so poor that the extra gain from the outside whip, you will struggle with reception anyway.
“One that can be stickied to the inside of the window, and is made for 4G”
Which 4G band though, depends on OP’s country, network & what band(s) are used where he lives
Think its Norway so B3 B7 B8 B20 B31 ?
Telenor 4G Bands:B3 (1800 MHz), B7 (2600 MHz), B20 (800 MHz)
Telia 4G Bands:B3 (1800 MHz), B7 (2600 MHz), B20 (800 MHz)
Ice 4G Bands:B3 (1800 MHz), B8 (900 MHz), B20 (800 MHz), B31 (450 MHz)
Most universal 4g aerials will cover Frequency Range: 4G LTE Cellular 698MHz - 2690MHz so all but one B31
Yes, however I’d guess that youd struggle to get more than 3dBi gain on a multiband antenna that would be partially offset by the typical gash 3m+ coax they are supplied with
Antennas behind glass sucks more than anything that has ever sucked before.
This is the inside antenna connector. What is its name?
