onurelmas
Hello, everyone!
I need a "Camping Mode" feature for my MG4 vehicle. When I'm spending time in the car, waiting for someone, enjoying an open-air cinema, or camping, especially at night, I can't use the climate control without disturbing others with my Daytime Running Lights (DRL). When I press the switch-off button, not only do the DRLs turn off, but the air conditioning also stops working. Adding a feature that allows the air conditioning to continue running while the DRLs are off would solve this problem.
In short, I see the lack of a "Camping Mode" button, which would disable the driving functions and lights but keep the climate control and multimedia functions active, as a significant shortcoming of the MG4.
I’d love to hear your thoughts on this and would appreciate your support for the campaign I've started!
Requirements for Camp Mode:
- The car should switch to park mode.
- All driving functions should be disabled (this includes sensors or other features that consume extra electricity).
- The driver’s display should turn off.
- The DRLs should turn off. Other lights should switch from auto to manual mode and be turned off, but they should still be able to be turned on and off as needed (a separate menu under Camp Mode could be created to control all the lights, including the DRLs).
- The multimedia screen should remain on. Pressing the home button for 3 seconds should dim the screen, and pressing it again should make the screen visible once more.
- It should be possible to watch films and listen to music.
- The air conditioning should be fully operational (this is the most important).
- The car should be able to charge in Camp Mode.
- The car should be able to discharge for V2L in Camp Mode.
- The car should only automatically exit Camp Mode under the following conditions:
- If the Camp Mode button is pressed again to deactivate it (with a warning).
- If the brake pedal is pressed, putting the car into ready mode.
- If the car’s battery falls below a designated level (in this case, the vehicle should shut down).
