Hi Dave - I can go into Ready mode (foot on the brake and pressing Start) and the dash will come up with a message warning me I'm still connected but it will not allow me to 'move' (i.e. nothing happens if I then press the accelerater - good thing really as I'd undoubtedly be driving down the road at some point with a Type 2 cable dragging from the front of the car!
Cheers
Bloggsy, it is warning you that you have tried to put the car into the ready mode, it won't show-ready in green on the dash between dials at the bottom, that is the only time the car is actually in the ready mode, it is giving you this warning to help you understand why you can't drive off, if you can see the green word ready in the dash between the dials and charging when you do this then it is an issue. The only time the green word ready stays on in the dash ( between the speedo and efficiency dials is when you press the brake and press the start button, the button only needs to be pressed once with foot on the brake you can then drive off and the word ready in green writing remains in between the dials for the rest of the journey. Next time you are charging and you press the brake and hit the button and the green word ready is on between the dials and stays on let me know please, you should find it reverted to the HV accessory mode you then have to switch off the car before you can remove the cable and then drive off remembering to close the charge flap???
