Excessive internal condensation
NJCS
N London - UK
EHS Luxury
Has anyone come up with a similar problem....winter worst as ice forms on screen internally.....would like to hear from those who have and maybe found a definitive solution if possible?
Cover the screen on the out side but will still gat condensation just start the engine to get heat. One reason went electric can just defrost for the arm chair.
Do you have a sunroof? I think it is to do with it not closing properly. I had extensive condensation inside too and about a month ago I tried to open the sunroof and it was jammed. When I tried again after a few days it did open but with a loud sound from the motor. I closed it after that and ever since then I noticed less condensation and no water pouring from the sun roof as it used to.
Don't know exactly what caused this though but curious to see if others had a similar experience.
I do, but it is rarely used, and there are definitely no signs of water ingress. I will check to see if it is fully closed, as you seem to have had some success.
I agree with your initial post. Worst car I've ever had for it. It has been reported on here previously and just seems to be a characteristic of the car, unfortunately. Just have to use the aircon and heater fan a lot I'm afraid.
I had it on an Audi before, but once leaves and debris cleared from the vents, it stopped. So, I will try that, but thanks for your take. Now waiting to hear from anyone without the sunroof
