medichi
On our second MG5 having been very happy with the previous one. Had a nightmare yesterday when driving to a wedding 2 hours from home. Plugged into a Gridserve for a quick charge (was sitting at 50% so nowhere near empty) and the charger came up "out of order". Disconnected and tried to move to the next bay but car would not move - dashboard lit up, both indicators flicked up, but then all shut down again. Left it a while, no better and had to bail out and go to the wedding leaving partner with the car. RAC eventually turned up but only a recovery vehicle so not even an attempt at diagnostics.
Car is at an MG garage today, but they won't even start to look at it until tomorrow - I'm hoping/assuming this has been the "failed charge" issue I can see on a few other threads, and a quick reboot will sort it (? software update) but now new anxiety about fast charging in the future (planning a long trip in the Summer).
I've seen a few mentions of the 10mm spanner "trick" but are there any videos or step by step of it? I'm not the most technical.
Also some mentions of Carscanner, Wifi devices and other tech to scan and erase erroneous error codes - are these useful for the MG5?
When was the last major softeware update and how do you check the version you are/should be running?
Apologies if this is all elsewhere, searches bring up references to all the above but not a 100% answer!
