@Shengis From my initial inquiry email to installation it took eleven days to have my Zappi set up. My fuse box and main incoming fuse is in a cupboard under the stairs and shares a wall with the garage on the other side, so the installer drilled a hole through that wall and ran the cable along the skirting board of the garage and up and around the top of the garage door to the other side. Another hole was drilled there to the outside of the house to connect the cable with the Zappi.
I’m sure if you explained your requirements they’d get back to you about the feasibility and costs for materials. You might need more or less cabling than I for example. As the cable ran around the garage I wasn’t fussed about it showing.
Anyway, I’m enjoying looking at the myenergi app which details how much energy my home is drawing from the grid. Once I have the MG4 and solar installed, it will be even more beneficial. The Zappi has a lock code to stop anyone tampering or using it without my permission, so that gives me extra peace of mind.
In the other photo you can see the extra fuse box that was installed and a myenergi Harvi module that communicates via radio frequency with the Zappi to monitor grid, solar and battery storage usage when installed. The whole installation took about four hours, but probably would have been quicker if I hadn’t chatted so much. ?
View attachment 12889View attachment 12890
