Hybrid Odometer Not Relevant
glend14
Australia
MG3 Hybrid+ Trophy
I was recently watching a Utube video from the "I Do Cars" engine tear down expert, and he was disassembling a Prius hybrid engine which failed at 73,000 miles on it. He pointed out the meaningless nature of Odometees in Hybrid cars, as a way of actually knowing how much wear the engine has been exposed to, because Hybrid Engines do not run all the time.
This got me thinking of the situation with my MG3 Hybrid, which seems to be primarily running as an EV most of the time. Perhaps these cars need an Hour Metre, which tracks actual engine run time. My boats in the past all had engine hour metres, as this is the defacto standard for marine engine service interval measurement. What do you think?
The MG3 Hybrid does have a run time total in hours/minutes, it's in the 'Accumulated Totals' of the Driving Data on the right hand side of the driver display. I'm not sure if this can be reset because I don't want to reset my totals.
It's true that Toyota users can use the application to find out how long the electric motor and internal combustion engine are used on a given journey.... and in cumulative terms too.
It would be great if MG could learn from them.
Clive, I am familiar with the display you mention, and the trip meter display available there as well. From my observation the trip meter records the time the car is turned on and that is regardless of what mode it might be running. That trip meter info is added to the accumulated total on the following display page but again shows system run time, not engine run time, in my opinion.
As Italy points out, it should be a very simple software patch for MG.
I can confirm it can be reset.
