Max size Roof Box
Mg69
London
MG5
Hi i need to maximise the size of my roof box, what is the maximum size Roof Box that people have put on their MG5 and being successful
Only the LR has the weight certification to have a maximum load of 75kg including the box and bars but the box will also have a limit. So even if the box is rated at 75kg if it weighs 20kg you only have 55kg capacity
The strongest position for the bars is just behind the front rail feet and just in front of the rear feet and that gap needs to be at least half the length of the box. Too long a box will start to "nod" over bumps
It will also have a significant effect on your range unless you go really slow.
Some pictures here as an example...
I have a Kamei 510 (new model released now), originally bought for my Grand CMax but used on my MG5LR. Photo in my profile
I positioned the bars based on a combination of the MG5 manual (which is vague but says mount as far forward as possible) and the Ford manual (80cm gap between bars) - so placed front bar just after the join, and the second bar 80cm later - this is within the range provided in the box instructions (62cm -> 87cm gap)
