brotherkennyh
- May 21, 2024
- Swadlincote
- MG4 (2022-2025)
Hi all,
I have had a great couple of days owning MGs. Both cars went completely flat. Personally I think there is a design fault with the charging. Has anyone else had similar issues?
One car is an MG4 EV and the other is an MG ZS EV, both 2023 plate.
The only change on my part is that I have left them plugged in overnight and set charging to start as soon as the car is plugged in. Originally it was on a schedule. This is the only change.
The MG 4 EV was purchased approx. 3 weeks ago. So initially I contacted the dealer assuming there was a fault with the car. The car had no power at all. I had to unlock the car with the manual key. I even climbed into the car to unlock the EV charge socket from the manual release so I could charge the other car. The car was driven for an hour before being charged so the 12V battery should be been fully charged off the HV battery before connecting the EV charger.
The MG ZS EV is now also flat. We have had this car since last August plugged this in yesterday after managing to disconnect the charging cable from the other car. This car is now also completely flat. I had to unlock it with the manual key again. It brings up some warning about the 12V battery voltage on occasion, but otherwise the battery has not been a problem. Even when it brings up a warning message about the 12V battery being low the voltage shows at 13.8V.
I had the AA out to start the cars, both cars showed 3V in the 12V battery. They took a couple minutes to start-up and then took over charging the 12V battery from the HV battery.
The ZS was completely fine after charging. The MG4 has a whole list of systems that are not working, mostly drive assist systems. Its now booked in with a dealer for diagnostics.
I not I also contacted MG before booking into a dealer. They were really not helpful at all and the only suggestion they offered was that the EV charger must be at fault. They suggested I take the car to another charger and try that. Amusing considering at the time I had not called the AA so the cars would not move. To be clear the cars charge fine, its just that they discharge the 12V battery while charging. This is fine for a short duration charge, but if its left plugged in the car goes flat.
The EV charger does not charge the 12V battery so I can't see how the car can be blamed. The car is responsible for keeping its 12V battery charged and it seems to have been overlooked.
Cheers
Kenny
Cheers
Kenny
