MG4 luxury HUMS loud when cold at 35mph+
sava1e
Amsterdam, The Netherlands
MG4 Luxury
In the Netherlands it's now freezing two mornings in a row. The first 5 to 10 minutes the car makes a very loud humming noise when driving 35mph+. The tone and volume differs when increasing speed. When the car is heated after a longer drive / in the afternoon the humming noise totally disappears.
Anyone else having this problem / knows what this can be?
a recording here: (humming sounds starts from 0.07)
Could it be that the Active Grill System is shut when the car is cold and it's the air vibrating the shutters. When the weather/car's warmed up the shutters are open allowing the air to flow freely.
Might be worth checking there isn't anything stopping one or more of the shutters closing fully.
@NLMGSAN
@Ian Key
The bottom looks ok to me?
The shutters were closed normally when I checkled the car. Strangely enough they opened as soon as I pressed the brake pedal. After a minute or two the radiator? was full of ice because it was freezing. Not sure if it's related / can cause that strange sound?
I also did a drive by: outside the car the humming noise is not audible.
I will also let my tires checked, but I don't get why the noise would disappears when it gets warmer.
Regarding the rear undertray ... take a photo from in front of the rear wheels looking backwards. It's the leading edge of the rear undertray that's usually the issue. :)
We have an air to air A/C heat pump for the house , when its very cold and humid the air rushing through the outside unit causes the " radiator " section to ice up, it then starts running badly and makes a humming straining noise with the compressor. We have to switch it off and let it defrost then its fine.
I'm suspecting its the same for the unit in the car?🥶
Ok will make another one tomorrow!
Ice on the radiator seems to be related... If there is no ice, there is no strange hum and visa versa.
I don't get why the shutters open when it's -2 outside.
To be honoust, it was -5 this morning and I did not have a humming radiator. But I have no clue whether the shutters were open or not.
    Votes: 910 77.7%
    Votes: 171 14.6%
    Votes: 90 7.7%
