MG4 Rear Internal Light
ColThomas
Ware, Herts, UK
MG4 Trophy LR
Hi All,
With the absence of a rear internal light in my MG4, I have just bought this from Amazon.
Light
It attaches to a stick-on magnetic pad (making it removable for charging), is movement sensitive or on/off switchable, charges via USB, is slim and unobtrusive and only £10. I'm going to mount it to the back of the armrest console in the footwell, it could provide a good solution.
I'll follow up! :)
@Rolfe @Coulomb @Alb can we move this to the Accessories board please - perhaps merge with an existing thread like below?
Hi All,
Light
I'll follow up! :)
On the face of it, sounds a cheap and easy solution to (for me) a most annoying issue. Looking forward to your “follow up”.
Hi All,
Light
I'll follow up! :)
Depends on how bright it is.
Update: I have installed the light using the stick-on, magnetic pad provided in the recess under the arm rest and the light works very well. It has an upward and downward projection and it is bright enough but is more of an ambient source which means it doesn't interfere at all with driving (it is motion sensitive so is prone to stay on if there are rear passengers).
For a tenner, it's a good solution and if you don't like it, easily removed!
