MG5 pre-facelift V2L DIY hack?
mk0805
London
MG5 Exclusive LR
Hi,
I was just wondering if anyone can recommend a DIY method to use V2L on a pre-facelift MG5. I found just one post on here about it, but I'm not sure about the details of it, e.g. what kinds of items can be powered that way and also are there any better ways anyone knows of, than using a sine wave inverter?
Thanks.
As per that post, the simplest way would be to use a 12V DC 1.5kW sine wave inverter and connect it to the Aux battery terminals.
The car needs to be READY before you power an external load as otherwise the 12V battery will deplete rather quickly.
What rate does the 12V battery get charged at from the HV battery? 1500W sounds a lot to me - that's 125A at 12V !
Ok, thanks. However, I've found there are sine wave inverters which can apparently be fitted to any car, so does that mean they can be used to do v2L with any car or is there an advantage to doing it with my EV? Sorry, I'm not very versed in the technicalities of this
Vehicle to Load (V2L) is not connecting a 12V DC to 230 AC 'Sine wave' converter.
V2L is a plug in to the front where you charge up the car - at the end of the cable is a 13A 3 Pin Socket
I use mine to make tea on a long journey or if we are having a picnic - with a low wattage kettle.
You can purchase a pre-made cable for this - (It's the resistors in the cable that determine if it's a load cable or not)
Here is a video on it - OK it's not an EV5 but same prinicpal
Here is a cable supplier (I'm not related in any way)
Here is some more info on this website
The normal advantage of V2L from an EV is that it has a large capacity 51, 64 or 77 kW/h (MG4) HV battery pack and an onboard inverter. So all you need to supply is a type 2 connector to 13A adaptor cable and set the car into discharge mode.
Using the regular 12v battery will severely limit the time and the loads you can use via an inverter to a few hundred watts as the kW/h rating of the 12v battery is about 0.5Kw/h
Putting the car into ready mode in theory means the 12v battery will be charging, but I'm not sure if the charge via the onboard CCU and HV battery would be enough not to flatten the 12v
The pre FL MG5 doesn't have any of the hardware required to do proper V2L.
Depending on what you are intending to use it for is perhaps best to get an inverter that you can connect to the 12v battery.
Does anyone know how many watts the DC/DC converter on a pre FL can supply to the 12V circuit?
The one advantage an EV has is that it can be turned on and supplying power silently.
The CCU is protected by a 150A fuse which will give you on paper about 2000W.
When the car is READY, all low voltage power is supplied by HV battery via the CCU , e.g. there is no load on the 12V aux, hence it cannot be ‘flattened’
The alternator on an ICE car has the same functionality as the DC/DC circuit (CCU) in an EV therefore this will work with any car. But as already mentioned, an EV does this silently and without exhaust fumes..
