MG5 SE
Craig285
Manchester
MG5 SE LR
Hi
Just purchased an MG5 SE & I'm loving it so far. I just have a question on one of the settings of the car which I'm struggling to find the answer for. Under the settings for charging there is a discharge option what % should this be set at?
Thanks in advance.
Welcome to the forum.
The discharge option is for when you are using your car to power another an appliance like a mower, kettle or camping fridge. Have you got V2L cable?
Ohhh I see, I had no idea that was an option. So I'm guessing it doesn't really matter what % this is at on the car unless I'm using it to charge another appliance?
Hi
Thanks in advance.
This should be set to the level at which you will stop supplying power, eg if you set to 20% it will not supply power, this is to protect your drive battery from being totally discharged.
