Multimedia Screen Brightness
demirbas44
Türkiye
EHS Luxury
Hello
I own a Mg Phev 2023 model vehicle.
While driving at night, the brightness of the multimedia screen is too high, even though I set the screen brightness to 0 in the settings, it is too bright.
How about other users? If it is the same, is there a solution?
look in you manual there is a setting in the information screen for day night.
Thanks for the answer
In the settings, day and night are automatic and the night light value is 0, but it is still too bright and I have to turn off the screen.
I think you are looking at the speed and power screen in front of you. On the info screen you need to search for display in I think sttings and in there there is a setting for day/ night / auto mode. Press auto mode so turns green and the info screen will change and its not bright in the dark.
No, I'm not talking about the screen.
We are talking about the same place, the multimedia screen, and although the settings are as you mentioned, the screen is quite bright when driving at night.
If you got the settings right then there no more you can do. That how it is.
Just thought your sensor may be not working to tell night and day.
Put the screen into standby by holding down the home key for 5 seconds, it will then display a clock which has a dark background so will be a lot darker, though that means no music and no GPS while the clock is displayed.
