Radio completely unresponsive
Tight Git
Yorkshire
MG4 SE SR
The radio on my 2022 SE SR has become completely unresponsive. When I press a button it appears to change station or between DAB/FM but nothing plays through the speakers.
When the system boots up it comes up as 'synchronization succeeded' as normal and about 30 seconds later flashes up 'USB disk identification failure' - there is no disk in either socket!
I am sure it has frozen and locked onto radio stations that are about 100 miles from home as it did this on Sunday and when I was back down there yesterday it started playing again but as soon as I leave that transmitter region it stops working.
Before I get on to the dealer has anyone had this or have any suggestions? I was thinking of disconnecting the 12v battery but suspect that won't help as that won't reset anything.
TIA
That sounds like the DAB radio firmware needs re-flashing. It's a separate box to the main infotainment system.
It's connected internally via a USB connection so if it's not working right that would explain the USB disk message.
    Votes: 908 77.7%
    Votes: 171 14.6%
    Votes: 90 7.7%
