Radio not working
Alan W
york
My radio keeps failing. On start up I get the following message, U disk read failure.
There are a few threads about this. Disconnect the 12 volt battery for 10 minutes and that should cure it. It worked for mine last week.
This is how I fixed my radio and the U Disk Identity failure issue.
Note that you only need to remove the Negative - clamp (mine was coloured blue) on the 12v - you can do that with a small spanner. You dont need to touch the Positive + one.
