Regen dash display
Wendycar127
Lanarkshire
Good morning.
I have just joined this group having picked up an zs ev 20 plate yesterday.
My question is when I did a test drive im sure the high voltage battery had a display showing how much regen braking had generated. I cant seem to see that now. Apologies if I am making no sense. Can anyone assist.
You have the "power dial" on the RHS of the binacle which goes below zero when you are "regenning" (if that's the right word for it?). Not sure there is anything else to tell you how much you're putting back into the battery?
Also 3 clicks down (right side of steering wheel) from the speedo display will show you the volts / amps (power use/regen happening amps) as they happen. However there is no display as in a percentage etc.
Thank you.
Thank you I will try that today.
