Replacement Windscreen Wipers (front)
drjat
Warrington, United Kingdom
Would these fit MG5EV:
Bosch Wiper Blade Aerotwin A980S, Length: 600mm/475mm − Set of Front Wiper Blades
They are a good deal on Amazon
Bosch Wiper Blade Aerotwin A980S, Length: 600mm/475mm − Set of Front Wiper Blades https://amzn.eu/d/0kHoVGo
The 600mm will surely fit but wanted to ask if the 475mm can be used in stead of 450mm please
It could be tight as there's only a 20mm gap between the blades in the parked position.
At that price it's worth giving it a go as you always have the option of returning them.
The correct blades (length and car fitting) are Bosch A721S
Remember to set the blades to maintenance mode to avoid scratching the bonnet edge. It's in the manual.
This I think is incorrect it should be Bosch Aerotwin A188S, 18 & 24” , I looked up wipers on Euro car Parts & it recommended 26” & 18“ then checked Bosch A721S and that’s a set with 24 & 16”, I couldn’t find the spec in the manual so then checked the car which still had the original blades on & thats 24 & 18. I found the A188s in a previous thread. They had none in stock when I went to the shop & they gave me “Starline” blades, half the price of Bosch, guy said they were very good, I suppose I’ll find out :)
