Sat Nav mg zs ev.
Joe
Halifax, UK
Hi All,Can anyone help me with my 2022 MG zs ev the sat nav has no colour like you would see on google maps etc, it just shows like it is night mode and the voice command doe not work on steering wheel, any help would be very appreciated.
There is a dark mode and light mode no satellite mode like Google
As for voice commands only the trophy has that I don't know if it works with satnav?
You can get voice commands if you use Android Auto or Carplay.
thanks for reply, but a want to know why is my sat nav not in colour like in a video review i have seen this is the first car i had that's not a colour map, it's almost like it is in night mode.
Can you post a pic
Have you played with in light mode and dark mode
Have you got your lights on?
Have you tried 3d layout ?
Hi have tried all of what you said but no change at all..
That's night mode that normal shows when headlights are on
yep your right but can not get it into normal made no mater what, the head lights are on auto also tried turning them off but no luck. how the hell do i get it to work normal mode.. thanks.
Try this swip left from home screen tap settings
Then under general switch on background auto switching
In auto lights off will look like this or you can have permanent light mode but that to bright at night
Auto is the best solution
Try this swip left from home screen tap settings View attachment 14634
Hi thanks very much for your help, thats what i have been doing did not realise thta that is the correct setting with a bright screen, thank you. now i need to get voice command to work as it works when iphone is plugged in to usb but thats just for the phone, but what i have seen you use vice command to open window and sunroof.
You may find this useful
As for voice control for Windows you need the connect model
