EVentropy
- Jul 10, 2024
- Age
- 74
- Location
- Auckland NZ
- MG4 Standard
The following observation I should have done when car was newer. Or better, new, with periodic data points as it aged. Alas, I was occupied with other things.
Car was charged to 100% and after a ~4hr rest:
HV= 349.xx
SOC =100% info 103.xx% car scanner
HV/LV delta = 170mV. Car scanner ( 3.44V, 3.51V)
Drove to store 2km and delta had reduced to 50mV.
Drive up hill a bit 500’ vert delta dropped to 10 mV,
Possibilities?
1. My car is not balancing and is faulty and bms is set to highest cell reaching approx 3.51v to disconnect charge bus.
2.Balancing is somehow done via discharge bus, or surface charge blows off high cell first and this is just characteristic of LiFePO4. And MG’s blurb is bs.
3………
Merry Xmas and the best discharging to you all!
HV= 349.xx
Possibilities?
3………
