Big Ears
- Jul 26, 2024
- Location
- Bradford
- MG3 Hybrid+ Trophy
This will start part way through the video.
The problem is they need to be fit for purpose. If the car keeps warning you when doing 70mph on a dual carriageway because it thinks the national limit is 60, when it picks up a 30mph limit on a side road or can't read the sign because it hasn't been cleaned or is partially obscured by vegetation. You end up ignoring warnings all the time or worst still have the car change speed in response to erroneous software.Speed warnings and mandatory speed limiters are great
Just my 10 pence
I can understand that, the problem is I think these 'aids' can lead to drivers applying less attention to their surroundings than normal.My daughter was nearly hit while using a pedestrian crossing with me (on a green man) by a speeding driver who wasn’t paying any attention so I am a little invested emotionally.
The car still has a normal accelerator and separate brake pedal. One pedal driving means that when you lift your foot completely off the accelerator, the car will slow like it's braking. Full one pedal means it will steadily come to a full stop. For normal driving, I think one pedal is really cool - you anticipate what's coming up and soon learn just when and how much you need to lift off. Of course if needed in an emergency, quicker stop, or for any other reason, you can use the fully normal foot brake.I have seen comments of some cars having only one pedal, is this a fact? stupid if it is, the boss and I were watching that motorway program where they assist in collisions and break downs, half of them are due to stupidity breaking where there is no need to break, not understanding what the conditions are or how to adjust your driving, the ACC is the only thing that will help there, I said to her they don't teach people to drive anymore only how to pass a test, and I've heard it said that it's the same for schools and universities.
Just takes a bit of getting used to, but takes the hassle out of it all.When on the motorway I use ‘no-pedal’ driving. I just set the ACC to say 70mph and then just change lanes as necessary. My MG ZS EV just slows down for moderate or severe congestion. It has gone all the way down to 10mph and then back up to 70mph when the congestion cleared. When the limit drops to 50 for roadworks, I just flick the ACC lever down to the new limit. I once drove for two hours without touching a pedal.
Kev, if you set up one of the star buttons on the steering wheel, for regen, you can toggle between each level, without even looking. Which is good, because the writing is too small on the screen. The default is on 2, so one press will bring you to three, press again, and you are in the lowest level. Press again and you are back to two. I agree it would be too much hassle to go through the menu, and too distracting.Thanks, It did seem a bit silly.
I'm not sure the MG3 regen is that good, I'd happily turn it off as when I am on a hill or see the lights changing to red I like to coast up to them, but regen slows the car down too much so I have to gas it again so no real saving and as it's self charging I'd rather waste a tiny amount of fuel.
I'm not saying regen is a bad thing, I just think it is very over sensitive in how it operates, I'd prefer if it only came on when I brake, not tried it on 1 yet as I always forget as like a lot of it it's too much of a phaph to keep going into the damned nanny settings.
The following report looks into this in detail. It is a bit heavy in places but compares drivers familiar with the technology in their cars to those unfamiliar with it. The research in this instance found that drivers with experience of advanced driver assistance systems (ADAS) technology were nearly twice as likely to be distracted while driving when ADAS is switched on, compared with when they were driving without help. The drivers with limited experience using ADAS technology were far more attentive.I can understand that, the problem is I think these 'aids' can lead to drivers applying less attention to their surroundings than normal.
