farrells
Hi All, quick question.
I've got a Jan 2023 ZS with squeaky front Windows. When the windows go down they are fine, when I stop them mid way, after they stop they squeak for a few seconds like they are settling into their final position. If I lower the windows and then immediately bring them back up a tiny bit there is no squeak. I've lubricated the window channels with spray grease and WD40 but still happens. Wondering if its worth while just spraying WD40 into the door housing with the windows up to try and get the mechanisms, might need a lube but don't want to take the door cards off unless I absolutely have to, would this damage anything (apart from spraying oil all over the glass). I've also noticed that the passenger side front window starts to squeak a little when put all the way up, after it reaches the top, takes about 5 seconds before it stops making a noise.
