Stability Control ZS
mj224
South West Wales
ZS EV Luxury
Whilst fiddling with a couple of controls, I seem to have managed to switch OFF the Stability control. Panel Reads ESC OFF
For the life of me I cannot turn it on again using the RH keypad on the steering wheel.
Any clues?
(page 22 in the handbook)
I think it re-instates itself when switching the motor back on...??
If that's so, one seems to be able to switch it off, but not back on.....??
Confused of South Wales..:D
Hi, I'm very new to this too but it appears on our car that the option doesn't change from ESC Off regardless of whether it's on or off which is pretty unhelpful. The only way I could tell was that a symbol light comes on the dashboard when it is off and I think you get a warning on the dashboard screen too to say be careful etc, etc. I pressed it again and it turned it back on again (the light went out)
We're still trying to work out what updates the car has already had so it might have been fixed with one of the previous updates that we haven't had (or not!)
Any clues?
To turn it back on go to the settings menu on the display between the dials. ESP deactivation is under the settings and can be switched on and off with the steering wheel buttons.
As others have said, when you turn the car off and back on it will be activated once again automatically.
