TPMS Fault Consult Handbook
Nanu
Admit Israel
Hi
The car ia a MG EHS PHEV.
I am receiving the warnings shown on the attached images.
.Pay attention to imagine "TPMS-02". No pressure or temperature are shown for any of the four wheels
Please help.
TIA
Nanu
Depending how old the car is the battery in the sender may have run out or there is a fault on the system. The quick way to find out is go to a tyre place and as if they would check it for you with there reader. Have checked your tyre pressures.
Upvote 0
Car age is 1.5 year. The pressures are OK. Front 2.5 Bar rear 1.2 Bar.
Upvote 0
Check out your pressure in the handbook on on line at My MG or on the door as those don’t sound like the correct pressures. After that if the readings don’t come up try a tyre place.
Upvote 0
To have all sensors display nothing says to me there is something upsetting the transmissions to the car or the car itself.
I had similar on a different car which also took out the remote central locking. Is your fob working (i.e does pressing unlock ON THE FOB work?). They transmit on the same frequency as the tpms.
Upvote 0
Here in Malta dealer sticks rigidly to the manual.....and so do I:
PHEVWheels Unladen Condition Cold
Front Wheel 250 kpa/ 2.5 bar/ 37 psi
Rear Wheel 250 kpa/ 2.5 bar/ 37 psi
'Sender' thankfully has not stopped working yet. But at least I am aware of the possibility.
Upvote 0
