I used a “Granny” charger for a few months while deciding on if I should invest in a wall box.
Which I did go ahead with way back in 2016.
The socket used for “Granny” was on its own dedicated circuit and a very short cable run of only about 6 - 8 feet in total.
After a full charge, the top of the 13 Amp plug on the Granny would get warm, not hot, but warm especially on the live pin area that carried the 13 Amp protection fuse.
The top of the wall box also gets warm at the top of the unit, when it is conducting a long charge cycle.
So, in this respect the heat generated is about the same.
Warm, but not mad hot ?!.
The thing to consider here with using “Granny” units on a older domestic supply, is that when these older houses where built, nobody ever imagined back then, that we where going to be driving electric cars and even less, that we would be demanding such high loans to charge them !.
Today, some modern electrical items demand higher loads than the electrical systems where designed to take.
Older systems running on tumble dryers / electric showers etc etc where unheard of.
The main cut out fuse ( owned by the DNO ) is a good indication of how things have changed over the years.
Our house and the surrounding properties where built in the early 80’s.
They are all running on a 60 Amp main cut out fuses.
Back then, this was seen as plenty big enough for the level of demand placed on the system.
Now all new builds get a 100Amp cut out as standard.
This displays just how times have changed in that fairly short time frame.
