Kayged
- May 21, 2021
- Age
- 70
- Location
- Fareham, Hampshire, UK
You will need a Type 2 cable so that you can charge away from home so there is no point in the added expense of getting a tethered unit as you can use the one you get for the carGot an MG EV on order. Any recommendations on which is the home charging point to go for?
Zappi and Podpoint seem to be the main two. I’ve found a local installer who will get one installed before the grant cut off next month but he’s pushing the Zappi 7kw tethered
