Why are tyre grooves not evenly spaced?
okohll
Bristol
MG4 SE LR
Noticed that the grooves in the stock MG4 tyres are not evenly spaced. They vary between 2 and 3cm with no particular pattern.
This seems to be common, see also images
but there doesn't seem to be any well know reason
Does that only happen at one spot, or is it random around the whole tyre?
If it's only one spot, then the grooves aren't divided equally around the circumference but are a default distance apart, so the start finish spot, will be shorter.
Random
I've heard it was for noise reduction. it makes sense that if you space them apart equally, a tyre drone could happen at fixed speeds.
Ah, that could be it!
Well what do you know, that is confirmed by
around 8 minutes in.
Started watching that after @Ian Key posted some videos about batteries from the channel in another thread
