Windscreen
I don't use the A/C, just make sure the outside air option is enabled (auto mists up like mad as the car has no humidity sensor), and the blow on screen is also selected.
I leave mine on all the time as set above and only adjust the temperature as required.
Ditto. :) In my case the temp is set at 22C (as I've had the HVAC update, so 22C now does what 25C did previously. Plus the HVAC seems better than before).
Same here as Ian, I want fresh air. I do go to re-circ when stuck behind a smelly truck or before using the wiper spray as I don’t like the smell of the water additive.
Normally no issues with misting. In extreme cases the demist button might be needed for a few minutes.
I select it when I first get in the car and the screen is misted up but after it clears I find it's not needed.
I think you're talking different things ... @Ian Key do you mean you press the Demist button below the Infotainment screen if the screens are misty? (I think @tsedge was talking about the windscreen vent icon ... to the right of the airflow [recirc] icon).
You're right. OK I find I don't have to select either the button below the screen or the virtual button on the screen once it's demisted 😁
Also, I cleaned all windows with Acetone and I rubbed with paper.
Pay attention for that.
Never put acetone on plastic because it burn it or change color.
I'd be very, very wary of using acetone anywhere on the inside of a car. Far too easy for it to drip/spill somewhere it shouldn't.
I use Isopropyl Alcohol for cleaning glass and metal surfaces but even with it you still need to be careful.
It's the go-to cleaner for prepping the duco of your MG4 before you install the fangs ;)
I have two 1 kg dehumidifier bags in mine, one on the dash and one on the rear parcel shelf, behind one of the headrests so it doesn't fly forward.
    Votes: 908 77.7%
    Votes: 171 14.6%
    Votes: 90 7.7%
