Wendwell
Hi. I have a Zappi WiFi-controlled charger and when charging my MG5 Trophy direct from solar panels, the charging starts and then at some point cuts out.
I raised with Zappi/MyEnergi and got the following reply.
It looks like when the car is charging with solar and the sun goes behind a cloud etc the charge will stop and then try to start again but it looks like your car doesn't like the stop-start of this setup.
I assume this response is in part based on Zappi remotely checking my device, which I had authorized.
Have others found that a passing cloud has this effect on an MG5 or other MG EVs when charging directly from solar?
I would appreciate replies stating which model/s you have had experience of.
