Zappi - timed charge help needed ......
Check the time on the zappi - mine was nearly 3mins out of sync during Christmas day.
But i do find the zappi does take upto 2mins to start charge. Its the PEN checks it does first and then waking the car up, it trys the normal method and then uses a special method zappi develop with a customer's MG.
My settings that work:View attachment 1152
If you have it in eco mode it will charge at 1.3kWh(from memory), you need to the app to eco+ & 100% and it should work with your timed selections.
Note I've setup mine for longer than the 4 hour period incase equalisation is required.
I had a problem setting timer, however, this has solved problem. Thank you!
My Zappi has worked perfectly since day 1 apart from I cant get the app to load onto my Ipad...works in both my phone and my wives so not sure what the problem is. great bit of kit especially with the Eddi, Harvi, Hub combo.
The only issue I have is there awful app. Its all cloud based, so if myenergi servers are down or slow, the app is also. When squirrels eat my BT line, i couldnt use the app via local wifi. Wished the hub had a bit more local control rather than an act like adaptor for internet communication.
But otherwise zappi and eddi are great devices.
It’s become noticeably more stable in the last few days - following their data centre upgrade - apparently there is an upgraded app to be issued shortly, which I’m looking forward to. Although the app can be a pain, you always have the option of operating it from the Zappi itself - although somewhat defeats the purpose of having the app in the first place.
