DragonKing
Improvements of infotainment I would like to see (items listed first have priority, like next update , others later):
•Driver 1 and Driver 2 profile with settings that are saved like Driving mode, seats, mirrors, heat and fan settings for each individual profile and remember so you get same settings/mode next time when you power on the car, there can also be standard profile witch works like orginal and resets in normal mode like it does now
•4wd stays on always in winter mode not go off below 20% battery remaining!!,, it can stay unchanged in normal and eco mode and do battery life extension by turning off 4wd in these modes
•Get downloadable updates on website Both GPS and infotainment updates so user can put on USB stick,,, (no need to go always to dealer)
•Car lights: toggle switch to make rear park lights turn on with front driving lights (it is mandatory to have daytime running lights both front and rear here in Iceland), now I always have to remember to turn on the rear park lights in the bright day and for sure forget to turn them off when I leave the car
•After running heat/ac from phone app get same setting as when car was turned off when back in the car and have pressed power button and maybe get more control in app with temperature
•Get scheduled heat/ac (time based) in app and toggle switch to choose if lights turns also on
•Door handle also goes in when toggle auto door lock off
•When driver assistance monitors/sensors are unavailable (in snow condition or other weather) and acc cruise goes off, then the steering stem goes automaticly to regular cruise control
•Option to show Left instrument cluster display on the big screen also
•Show more then 30kwh ave consumption
•Show charging rate in kW on instument cluster and big screen when plugged to charger
•Option to record on Usb stick from the 360° cameras (as dashcams)
•Toggle switch for Sentry mode (like Tesla)
Do you have more suggestions which improvements you would like for your Marvel R?,, this could be a place for a list that MG Marvel R owners could offer to the software development team.
Nothing will happen if owners don't press on MG to do these kind of software upgrades/improvements to a otherwise great car.
