2020 MG ZS EV Air Con failures
javiermi
Eastleigh
For a while now, I'm having problems withe the Air Con: you want to demist the windows, so you turn on the air conditioning - just blowing air in, and a couple of minutes later it stops. You turn it off and back on , an the same happens. It's very frustrating, and dangerous if you are driving.
I also found that if you leave the air speed to full blast it stays on. Is not ideal, as it is very loud and you barely can hear the radio.
Took it to the dealer for a day and they asked me to leave it a WHOLE week..No alternative, but to agree. After the week they say IS fixed. After a few weeks , the issue happened again. After waiting nearly 2 months for a scheduled visit, they tell me everything is OK, so couldn't do anything. Took it home and for a few days is working OK.
Today the problems starts again.
I'm starting to get annoyed - and angry - why cannot the manufacturer fix a problem that seems simple enough? Surely under warranty they can change ALL related modules at no cost.
I'm thinking of writing s complaint letter: this is NOT right.
Any advise?, has anybody have had a similar experience?
What happens when you just turn air-con and leave it on as set temperature? Not demist but air-con
Not sure if you understood,it's difficult to explain
The issue is when you turn the air on- not necessarily the actual AC. BTW, this car has no option as to what temperature you want, is just " more cold or more hot"
so it's the fan speed/control? there were some posts with the same problem, search on the forum, it should come up ...
Found it - post your question in reply to that guy with the same problem, ask how he fixed it
Thanks a lot. I'll reply to this guy, hopefully he can help me
