NJCS
Can anyone shed some light on why the radio will not initialize? I have disconnected and reconnected the battery but same as before
Thank you for the response but this is a '22 HS Phev and if you mean the home button then yes. I believe I need the DAB firmware files as there is no version number showing on screen.Try the short cut button on the left side keep pressed more then 30 seconds
