Bazarooni
Seems there are differences with NMC and LFP that might make you think twice. I've copied a bit of an article on the differences below...
A longer cycle life indicates a better battery lifespan. It is an important consideration as it directly reflects the value for money factor.
Verdict: LFP technology produces a significantly better battery cycle life than NMC batteries and can last twice as long.
Then there's Depth of Discharge to consider, amongst other factors.
Full article is at Lithium NMC vs LiFePO4 - How to Choose the Best One for Your Needs - Eco Tree Lithium
Just something to consider.
Cycle Life and Lifespan
Cycle life is the number of charge-discharge-charge cycles a battery can sustain without any performance degradation. A single charge cycle is when the battery is discharged from its fully charged state and is then charged again.A longer cycle life indicates a better battery lifespan. It is an important consideration as it directly reflects the value for money factor.
NMC Battery
An NMC battery has an expected cycle life of about 2000-2500 cycles. It can provide full power for about three to four years but then suffers fast degradation.LFP Battery
An LFP battery has a typical cycle life of about 5000 cycles. It can perform optimally for seven to ten years, followed by slow degradation. In fact, high-quality Eco Tree Lithium LFP batteries come with a 6-year warranty.Verdict: LFP technology produces a significantly better battery cycle life than NMC batteries and can last twice as long.
