5LR exclusive car mats
Got this from CARMAT. Co.uk apparently the hole spacing is adjustable, hope it helps
Not sure how you did this but if you didn't know the plastic clips around the holes are adjustable.
There may just be enough space in the mat holes to adjust them to your mats fit better.
To do this you need to open the clips up, they should pull apart from either side of you can use a flat screwdriver to gently prise apart. To this to all clips at the same time.
Once the clips are apart, please position the mat in the car & the fixings in the footwell should fit through the holes in the mat.
At that point you can now see where the clips need positioning within the holes in the mat. This should only be a case of moving each by a few millimetres.
Now push the clips together from either side of the mat until they click through.
I hope this helps!
I hope this helps!
Thanks for this, job for this afternoon!
The hole centres are just under 445mm on my Mg 5 long range exclusive two week old 2022 plate.Ordered from carmats.co.uk purchased the higher quality ones which quality looks good. But unable to check with the lower price ones for quality. Sold my renault zoe car mats which I never used for £30 which was very poor quality .I loved both my zoes.just not the mats.So left me with only £30 extra to pay. Having inspected Mg 5 own range mats. The mats from Carmats.co.uk to me was much better buy came as a set of 4 with same colour trims
HELP!! Looking for rubber mats for MG5 Exclusive. Driver pegs 245mm. Passenger side 300mm. Can’t seem to find this combination. Has anyone resolved this?
bought for my 5 Excl. from carmats uk and although the size was a teeny bit off on the passenger side I decided to keep although they asked I take foties etc. when I phoned- I was in a couldn't be bothered frame of mind so - content with them. but your choice...
Just taken delivery of a set of rubber mats from Vehicle Mats UK. Front seats floor distance between pegs 245mm (driver) and 300mm (passenger); one piece rear seat, and a boot floor mat.
Perfect fit all round.
