Accident due to TJA/ACC use.
That is interesting. So an older version than my continental EU R46 starts up with OPD by default...
Does it also have the navi with the updated charging functionality?
If you look at the whole software code you will see R46 is older
You mean the separate modules are newer?
In that case I'm VERY curious what is in that package compared to R59...
Can you list the separate module numbers you can find in the engineering menu? So we can compare it with those from a recent R59.
Your software version is SWI68 (I assume you have a trophy model).
We got a new one on july due EU new regulations.
Thanks very much. Though these are not from the engineering menu. Tap software version 5 times until code entry appears and type 500219. In that menu you will find details about the version for the Tbox and many others. That could tell us how much really changed in the other modules. My May 2024 versionb
Nevertheless, what I do see is an implementation of ISA based on the maps. That is related to the mandatory use of speed assistance in the EU as of July 2024. That would cause a laugh herr cause the current maps do not correctly identify maximum speeds in NL.
Neither the multi tap neither the phone tab one works on my car.
Pins are different. You can se the greyed out ok button
    Votes: 935 77.6%
