Lovemyev
Distinguished Member
- Jan 23, 2021
- Location
- N.Wales ZS EV ( Gen 2 ).
If the noise you have is a clicking / creaking sound, that appear to be emulate from the top of the dash panel, where the top of the dash meets the bottom of the front windscreen glass.No this is for the creaking noise in the dash
That can be heard when travelling over a uneven broken tarmac road and appears worst when the outside temperature is cold.
Then it is extremely likely you have the same common condition that we are referring too.
Of course it could be something totally different, but this issue has been reported a LOT by ZS EV owners.
“A” pillar trim rattle is another common reported issue, but the rapid creaking / snapping noise that can be heard from the top of the dash area, is likely to be the famous scuttle panel gasket fouling on the outside of the windscreen glass.
Applying a spray lub between the rubber / hard plastic gasket will give you a quick and easy answer to if this is indeed you issue.
Better than having somebody pulling your car apart, trying to locate this problem.
Causing more problems than you started with, by breaking trim clips etc.
The best long term solution to this irritating noise, is to remove the scuttle panel completely from the car and apply some type of Teflon or silent tape, to the gasket and refit to the car.
This should prevent a hard foul condition / bridge between the gasket and the glass.
The lub spray just confirms the problem and offers a quick and easy fix that can be carried out without a trip to the dealers and is about 95% effective.
Unless you like offering you car to the dealer to fix of course ?.
Not me that’s for sure, I hate having to require intervention from the dealer.
I just find the whole experience hard work and stressful.
