peterseddon
Are there any problems leaving it plugged in all the time? I put one in my previous car and it brought up the red engine light when first started.
Here is a quick how to contactThanks chief. Really appreciate your help. Ordered one.
No problems with this one some will set alarm off but I wouldn't leave it in ie over night (I have done this without any problems) as it does draw a bit of current not worth risking it also if playing with it just have car in ready mode as it's good practiseAre there any problems leaving it plugged in all the time? I put one in my previous car and it brought up the red engine light when first started.
One thing to add is SOC is a bit lower then car display I think this is because it reads hole battery not just usable battery like the car shows
Morning, will this work with the elm 327 dongle? Thanks for all your input to this.
Yep that will work it's the same one I linked on Amazon that I have been usingGrand thanks. The nexa ones seem good. Is there a specific one? I found this one on aliexpress for € 24
NEXAS NexLink OBD2 Scanner Engine Code Reader EOBD OBD2 Diagnosescanner für IOS Android Windows Car Diagnostic Scan Tool - AliExpress 34
Smarter Shopping, Better Living! Aliexpress.coma.aliexpress.com
Thanks a mill
Car scanner. I’m iOS. I thought this was the one being talked about. My bad. Which ones do you use?What app is that don't recognise it?
Not really. I’m going through all the apps….! Will report back.The app that works on android is eZS I don't know iOS
Maybe you have an android tablet or an old phone?
I guess the question has anyone used another app other than the Nexa and viewed soc and soh using an iOS app?I have not heard of a iOS app dedicate to MG
Ouch could you not ask a friend to help if you only want to see the data occasionally?Here’s what I’ve tried without success!
