Gandalfharrow
For the last 4 days or more the app fails to "connect" on my Trophy LR.
This is very frustrating.
Car is in the open air.
Thanks, it appears to be a sledge hammer to crack a wallnut. But it often works with computers!Yeah, i had this also and has reported it to MG.
After 2 weeks i gave up and tried the good old "Disconnect 12V battery for 10 minutes" and after i reconnected it, the app started working again. (Did not want to do this earlier, as maybe they would need to connect to the car to do some diagnostic, but after 2 weeks i decided that if they had not gotten the data they needed, they were probably not going to.)
The app was partially working for me though...
Partially = Anything related to battery SOC, remote control and GPS position not working, but if i used the APP to make a satnav route and uploaded it, it would be sent to the satnav just fine.
Try disconnecting one of the terminals on the 12V battery for 10 minutes.
I have not tried the navigation so do t know if that still works!Thanks, it appears to be a sledge hammer to crack a wallnut. But it often works with computers!
Yeah, would be nice if they atleast had some "cold boot" button in the infotainment, that would do a full reboot of the modules affected. The "press the home button until the screen goes black" method did not work.Thanks, it appears to be a sledge hammer to crack a wallnut. But it often works with computers!
So now all we need is a timer, that via a relay, disconnects this fuse for 1 minute every night at 3 AMThere is. T-Box fuse - under dash, passenger side. Take it out for 10 secs, reinstall. It resets the telematics unit.
