JodyS21
Just a thought for you guys out there that are having very very low battery capacity issues.
I know there's a whole discussion going on about the battery usable capacity, however.
According to the warranty:
70% of 42.5kWh is 29.75kWh
So if you're one of those experiencing massive degradation and you believe you're getting less than this in usable capacity. Surely you are within your right to tell MG to either repair it or replace the battery (or even the car).
During a capacity check at an Authorised MG Repairer if it is determined that the lithium-ion high voltage battery has suffered a capacity drop below 70% of the original value at delivery of your new MGZS EV, the segment below 70% will be deemed excessive loss. Where possible the excessive loss portion will be repaired, if un- repairable the lithium-ion high voltage battery will be replaced with either a new or a remanufactured battery.
The car is delivered with a specified 42.5kWh battery - regardless of gross/net/usable capacity.70% of 42.5kWh is 29.75kWh
