Caramaddy
- May 4, 2022
- Location
- Deal in Kent
- MG5 Luxury
There was a recall for the PF MG5 because the brake lights were not working on regen 3
Personally i use many settings. In the heavy traffic in the morning i use eco+one pedal. Then on regular traffic i use default regen 3+eco. When there isn't much traffic i leave everything default and when in highway i use regen 1. Personally i used to the auto stop of the car thus i dont mind..I've owned my MG4 for over a year and had always previously set the regen braking at the lowest level - 1.
I don't like the highest setting, especially on motorways as the car decelerates rapidly without (I assume?) turning on the brake lights.
I've just discovered the adaptive regen setting and found it worked well on a long journey.
What do others use?
Any suggestion on what is the most efficient setting?
You're not kidding...28 deg at 8.30amHere is one of my regular trips, of the 10 kWh used I get 3 kWh regen which pays back some of the 1kWh my A/C used (it’s fairly hot here in Oz atm). I rarely adjust my driving mode from Normal.
That's my feeling as well. but others ague that on a straight road any pedal variation will cause losses.I would think that OPD is the most efficient energy consumption? most regeneration?
(all other driving habits alike)
I use Regen 3 all the time, can't be faffed to keep changing it :-D
But I like ReintjeWA's suggestion of using A on motorways - I like the AAC, but not the way the MG4 drives like a 15-year-old!
Indeed there was, and one of the other things that update did was to reduce the deceleration available in regen level 3. Grr.There was a recall for the PF MG5 because the brake lights were not working on regen 3
That is something I had not noticed.Indeed there was, and one of the other things that update did was to reduce the deceleration available in regen level 3. Grr.
I always assumed the S = Stop in other words the regen has the ability to stop the car rather than other levels which allow it to crawl between 2-3 mphWhen I switch on OPD my regen level is S. What does this mean and is it more than regen 3.
Totally agree.I use Regen 3 all the time, can't be faffed to keep changing it :-D
Good comparison. Agree, it's just like that.The throttle reacts just like your Scalextric did when you were a kid. (IMO)
I thought I read it stood for Strong, but could just as easily be Stop, because it brings you to a complete stop.When I switch on OPD my regen level is S. What does this mean and is it more than regen 3.
It’s warm here but not as warm as past summers. Did realise my household thermometer for outdoors was near the air conditioner unit which was ‘inflating’ the temp by 3-4 deg thoughYou're not kidding...28 deg at 8.30amIt's 6 deg but feels like 0 with a NE wind here
I notice your energy consumption screen is the other way round , the 'doughnut' is to the left and energy consumption to the right on mine. The buttons are in the same order. Why have you intelligent battery heating on
, does it get really cold at night
Me too…I find the braking/deceleration at that setting is as good for driving as I need without using the brakes much at all.I use Regen 3 all the time, can't be faffed to keep changing it :-D
