hmadsen
- Jun 15, 2021
- Location
- Denmark
- ZS EV Luxury
If the car has the cigarlighter plug connected directly to the 12V battery, even when power is off, he might even get away with just buying something like this and plugging it into the cigar lighter socket.ICE cars also suffer battery problems if left for weeks without use, mainly due to alarms and other continuous battery loads.
The solution is obviously a maintenance charger, but this is only possible if mains power is close and there are no issues with cables, etc.
Another option could be a PV panel and charge controller- I use one for my 1950 MG TD and it works very well for the long periods when the car is unused in a remote garage. For the ZS, it may be enough to put the PV panel under tbe windscreen?
Solar charger for car
I would imagine that the Cigar lighter is on the ignition 12V circuit.
That being said, it would still be possible to wire a device like this, to the battery and get a wire through to the cabin.
A bit of a shame, the ZS EV does not continuously measure the voltage on the 12V battery and just top it off when it gets low, even if the car is parked up. I know this is how other car brands make sure the 12V battery does not go flat, even if you park the car up at the airport for 2 weeks while you go to Ibiza.
