RossN
I have had the same problem with my MG5. I have it booked in to my local MG garage soon so lets see what your garage say as it looks to be the same fault.
Many thanksGarage just called, definitely a problem with car, they have sent the report to MG to decide what problem is and therefore what the fix is...I will let you know resolution.
What does it say on the car screen when you do a fast charge that would be more to the point I think.Update - car back having had various units updated (didn't go in to details as didn't speak to mechanic I am afraid). Asked to take away and test. Still doesn't communicate with CCS charger ×2 tried, just doesn't lock in place. Images of what chargers say will now be submitted to MG to advise on what garage should try next!
Andy
'Connected but not charging'What does it say on the car screen when you do a fast charge that would be more to the point I think.
What does it say on the car screen when you do a fast charge that would be more to the point I think.Update - car back having had various units updated (didn't go into details as didn't speak to mechanic I am afraid). Asked to take away and test. Still doesn't communicate with CCS charger ×2 tried, just doesn't lock in place. Images of what chargers say will now be submitted to MG to advise on what garage should try next!
Andy
That would suggest that the car is happy that the cable is connected correctly and it is waiting on the charge point to initiate the charge, I can't understand why the garage did not test it on a rapid before returning it to you, if there is a rapid charger near the garage get them to get in the car with you take it to the rapid and let them get it to charge, if you don't have a problem with an A/C charge the car must be connecting to the cable OK but it could be the DC pins on the car that are the problem, worth a try.'Connected but not charging'
I live about 100 metres away from the dealership in my village. As I can charge on my home 7kw charger I was happy to try myself and stroll the few metres to say 'nope not sorted' and to carry on using whilst they get advice from MG. Not sure it is a dc pins issue as on rapid type 2 will charge just at about 7kw max.What does it say on the car screen when you do a fast charge that would be more to the point I think.
Type 2 fast power points that are higher than 7kw make no difference to the original MG ZS as that is the maximum the car internal charger will accept, unlike the new ZS which has an 11kw internal charger which makes more sense as most ac power points Are now 11kw or higher.Less than rare, always charge at home. I did use when I first got the vehicle whilst awaiting home charger installation and it worked. It has had a service and software update in meantime and when I went to use on a long trip found it didn't work anymore! Vehicle is in garage at mome
no, and wonder if the software update mucked things up. Doesn't communicate with CCS at all and on type 2 rapid only at 7kw max(no matter what the charge rate of charger is).
Thanks for the updates. Interesting to see what they come back with.I live about 100 metres away from the dealership in my village. As I can charge on my home 7kw charger I was happy to try myself and stroll the few metres to say 'nope not sorted' and to carry on using whilst they get advice from MG. Not sure it is a dc pins issue as on rapid type 2 will charge just at about 7kw max.
Hi Andy. Have you had any info back from the dealers regarding the CCS issue?I live about 100 metres away from the dealership in my village. As I can charge on my home 7kw charger I was happy to try myself and stroll the few metres to say 'nope not sorted' and to carry on using whilst they get advice from MG. Not sure it is a dc pins issue as on rapid type 2 will charge just at about 7kw max.
Hi, On Monday MG needed convincing it wasn't the charger at fault so sent 3 images from 3 different chargers all saying charge disconnected by vehicle which seemed to convince them the vehicle was the issue. Dealership have been advised to replace the communication unit from behind bumper now. The garage have told me they just need to find a vehicle to get the unit from! Hopefully they will have done that next week and I will then update you further. AndyHi Andy. Have you had any info back from the dealers regarding the CCS issue?
Thanks Andy that's super let's see what they do and great as a result.Hi, On Monday MG needed convincing it wasn't the charger at fault so sent 3 images from 3 different chargers all saying charge disconnected by vehicle which seemed to convince them the vehicle was the issue. Dealership have been advised to replace the communication unit from behind bumper now. The garage have told me they just need to find a vehicle to get the unit from! Hopefully they will have done that next week and I will then update you further. Andy
Possibly, an AC charger such as my home one locks in to place and charges fine. Any CCS DC...nope. Car says connected but not charging, charger indicates communicating with car, then charger says charging session ended by car...immediately. CCS DC never actually locks in at any stage.I just wonder if the mechanism that should lock the charger head in place, is acting up? It could well then tell the car 'all is not Well' and fail to properly connect up.....just a thought.
If you wiggly the charge gun in the port and lock and unlock the car it finally locks the CCS gun in place but it's the same result that it fails to charge and the same error appears on all the 6-7 or so chargers I have tried.I just wonder if the mechanism that should lock the charger head in place, is acting up? It could well then tell the car 'all is not Well' and fail to properly connect up.....just a thought.
Hi, Communication unit replaced on my ZS EV but alas issue remains so they are going back to MG again for advice. The MG5 with a similar issue was still up on a ramp with unknown cause of problem. My money is on a locking mechanism problem as a 43kwh AC locks and charges (at 7kwh) but the CCS DC from same charger (see images below) just does not lock into place even though car says connected (but not charging). I shall await advice from MG again!Thanks Andy that's super let's see what they do and great as a result.
Well sometimes by locking and unlocking the car it does lock the CCS in place but it still fails to communicate and charge so I think there is more too it. Have a go- wiggle the CCS gun in the port ever so slightly and lock and unlock the car and see if it locks in place as mine did. This was the only thing. The AA call out guy figured out to do (made no difference though) as he said he had no idea how to work on an ev. Basically the AA are useless and have always been since my 1st encounter in the 1990's I have found and they don't seem to be working with MG regarding EVs as I was educating the AA guy and near 4hrs later we had to be taken home with a recovery truck. The AA are not real mechanics just people who what to work for them selves kind of. Green flag alot better as they always come out with a flat bed and tow you away straight away if they cannot fix the issue. Anyway I digress.Hi, Communication unit replaced on my ZS EV but alas issue remains so they are going back to MG again for advice. The MG5 with a similar issue was still up on a ramp with unknown cause of problem. My money is on a locking mechanism problem as a 43kwh AC locks and charges (at 7kwh) but the CCS DC from same charger (see images below) just does not lock into place even though car says connected (but not charging). I shall await advice from MG again!
Thanks I am sure we have the same issue so will see which dealership identifies the issue first! Will keep you updated.Well sometimes by locking and unlocking the car it does lock the CCS in place but it still fails to communicate and charge so I think there is more too it. Have a go- wiggle the CCS gun in the port ever so slightly and lock and unlock the car and see if it locks in place as mine did. This was the only thing. The AA call out guy figured out to do (made no difference though) as he said he had no idea how to work on an ev. Basically the AA are useless and have always been since my 1st encounter in the 1990's I have found and they don't seem to be working with MG regarding EVs as I was educating the AA guy and near 4hrs later we had to be taken home with a recovery truck. The AA are not real mechanics just people who what to work for them selves kind of. Green flag alot better as they always come out with a flat bed and tow you away straight away if they cannot fix the issue. Anyway I digress.
Thank you for the update so far. I now have a dealer slightly closer and I might see if they have a service center to and see if they look at my vehicle and update too. ?
ZS EV...Update number...well I have forgotten really!Thanks I am sure we have the same issue so will see which dealership identifies the issue first! Will keep you updated.
