Squeak
Hi all , opened the bonnet on my MG ZS EV 2022 Essence (here in oz) and noticed while changing that the CCU -(Combined Charge Unit) was quite warm when charging. I was very SLOWLY charging the battery pack at 6amps @240 (1.4kw) . Even charging at a high rate a few day prior I was charging @ 15amps (3.1kw) home charging, the CCU was still quite warm. Not liking electronics to get too hot, I installed 4 heat sinks on the posts of the CCU to help keep the unit a bit cooler. The M8 bolt threads were already taped into the posts from the factory. I did remove the Earth cable plastic holders and attach the cable to the left side heat sinks. After 1 hour the CCU was a lot cooler
