GadjoDave
- May 21, 2024
- Location
- Llanelli, UK
- MG4 Trophy LR
Equipment:
MG4 Trophy LR
3.8 kW solar panel array
Latest firmware, infotainment, and MGiSmart iPhone app versions*
MGiSmart Charging settings: Target Battery Level 100%. Scheduled Charging: Off. Scheduled Battery Heating: Off. All settings Saved.
Zappi tethered home charger with latest versions of firmware and MyEnergi iPhone app*
Tesla Powerwall v1 domestic battery with latest firmware*. 100% charged.
Octopus "Intelligent Octopus Go" tariff (cheap rate electricity 23:30 - 05:30)
* as of today (1/6/24)
When charging from solar panels using the Zappi's Eco+ mode*, the MG4 Trophy initially accepts the charge, supplemented by top-up from the Powerwall as required.
If there is inadequate current available (eg. sun gone behind a cloud, or increased domestic usage), charging would pause with the Zappi and MyEnergi app displaying the message "Waiting for Surplus". Then, when there was more output from the panels available, charging would resume automatically, and continue until the preset Target Battery level (eg. 100%) was reached.
*(The MyEnergi app is set to Eco+ mode with the "leaf" slider setting on 1% - ie. draw current from Powerwall or grid as required if solar panel output is insufficient),
This is the desired behaviour, and this is how my system worked until I got the most recent upgrade of MG firmware and MGiSmart iPhone app last week.
Since then, if the output from the solar panels dips transiently (eg. clouds moving across the sun; using electricity for domestic appliances such as boiling a kettle or using the electric stove), the MGiSmart app reports "Charging Completed", and the MyEnergi app reports "Charging Delayed" indicating that the MG is no longer accepting charge.
When the sun comes out again or the kettle has finished boiling, the MG subsequently refuses to resume charging, even though the charge in the battery is nowhere near the Target Battery Level, and any surplus electricity from the solar panels is diverted to be exported to the grid.
When I look at the Charging Settings on the MGiSmart App, it seems that they have spontaneously reset to: Scheduled Charging: On (Start time 22:00 End time: 06:00). Scheduled Battery Heating: On.
This is why the MG is not accepting charge, even when surplus is available.
I correct these settings and press Save again.
I then try to Start charging from the MGiSmart App.
The app sometimes requires me to re-enter my 4 digit PIN; sometimes not.
However it is unable to Start charging, and the message "Please Insert The Charging Plug" is displayed (despite the charging plug remaining inserted throughout).
The only way to resume charging from the solar panels is to physically get into the car and power it up.
I touch the "battery" graphic on the home screen, and go to Charging Settings where I find that these have all been reset to the same settings as the iSmart App (Scheduled Charging: On, Scheduled Battery Heating: On).
Again, I have to reset these to "Off" and Save them.
However, unlike the MGiSmart app, the MG firmware recognises that the charging cable is still connected.
I then have to press "Start charging" on the Charge Settings Screen, and charging resumes.
This sequence of events happens repeatedly when I am trying to charge the MG from my solar panels: basically every time the sun goes behind a cloud or a domestic appliance draws current for more than a minute or two.
Each time, I have to reset the charge settings on my iPhone app, then get into the car and boot up the software and reset the charge settings before charging will resume.
The fact that charging from the solar panels all worked fine until the latest MGiSmart App update; and that the MGiSmart Charging Settings ignore the saved values and keep resetting to "Scheduled Charging: On" every time there is a break in flow of current to the car during the charging cycle all seems to suggest that the cause is buggy software in the latest update of the MGiSmart App.
I'd be grateful for any shared experiences, advice or workarounds.
And if anyone from MG is reading this:
You have an potentially excellent EV which is being seriously let down by ongoing buggy and badly written software to the point which makes for an dreadful user experience.
I would currently hesitate to buy another MG or recommend MG to friends and colleagues.
A software fix is simple and cheap to implement. Get it sorted!
MG4 Trophy LR
