Charging on granny
P6cat
North Wales
Hi I’m sure this has been discussed here somewhere but I can’t find it
I have a Oct 2020 zs it shows about 456 v when fully changed
And I can’t change when car is open what update would be needed
I have no other issues with the car apart from clicking steering and
Infotainment system blacking out occasionally
Thanks steve
If you get about 160 miles on the GOM you have the pre-buggy BMS s/w, but if you see the range decreasing then you need to book it in for an upgrade. The charging unlocked is the EVCC, but it is tied in some way to the comfort 2 update. The info screen has a service notice to be updated at the next service. Clicking steering is a replacement column under warranty.
Yes, I had all this on mine.
hi thanks
ive had the info screen update I think, the range is fine and it’s had the comfort 2 , what’s the EVCC?
Thanks steve
The EVCC module needs updating, this can be done by the dealer EVCC = EV Charge Controller ?
