Padaung
Hi Folks, has anyone else had the following problem and found a solution to it?
The charging port is not closing on my 2021 MG5 (ie the flap does not 'click' shut). The pin that appears to have the lock mechanism does not reliably spring out and turn, so I'm assuming that is the problem. I've tried applying WD40 to clean it and then some bike chain oil to lubricate it, but with no success so far.
The times I have managed to get it to shut, it has then been tricky to open later on. I had to use a flat head screwdriver last night to help ping it open.
This video shows the problem:
Many thanks in advance for any suggestions.
