Check your 12V battery connector nuts!
toma
Italy
MG4 SE LR
Hi everyone, after 1.5 years of ownership of my MG4 64kWh the only big issue I had was that sometimes the car would give all the fault alarms at random times and 2 times it happened that the car complitely shut off (fortunately not when driving). The second time it shut off the car wouldn't even open and I had to unlock it with the manual key. In that moment, before calling a tow truck, I opened the bonnet and found out that the negative connector bolt was completely loose, so I screwed it down and the car turned back on. I went to the MG workshop anyway and I made him replace the standard nut with a self-locking nut because only the negative connector didn't have one. I even made him check all the fault alarms and he confirmed that it was only a 12V power failure. By the way the app only notified me about a power steering fault every time.
This is a known problem. The battery terminals should be checked on PDI. But some cars are obviously not.
    Votes: 931 77.6%
