Concerning creaking from the rear left
I'll ask the obvious question ... sunglasses in the roof-mounted glasses holder?
No not that. I think it might be behind the dash so I may never solve it. Can't hear it when the radio is on , it's kind of a vibration noise , it's just annoying. It seems to be worse when it's cold first thing in the morning, but still does it at other times too.
Yeah , it's not the screen, or the glove box . I might find it eventually but I think it might be behind the dash somewhere so maybe never fix it. Not really any issue , car is so quiet you hear everything. ??
Sorry for the late reply... I'm glad you sorted it out.
I've attached a picture of the final state of the bung (after twisting and pulling out a bit) and the tape wrapped around the loop (it may be that either one of them has done the trick).
Hi. The tape solution did not work for me.
It has been 12k kilometers since I bought the car and there has been a slight noise coming from the rear since the beginning.
I will try the other bung solution and post the result here. I ordered a cheap screwdriver set for this.
The tape in the picture is not on the latching part of the lock. It is better placed on the right hand side of the loop as it is pictured.
Thank you for your reply.
Actually, I didn't do it like in this post.
Update:
I'm posting what I just did, but the noise continued either way.
A simple wrap of insulation tape on the strike surface of the boot latch has fixed it totally! Was getting a creak in the rear of my MG4 as the car body frame flexed a little heading down the ramps into my underground car park. Also greased up the rubber stoppers and surfaces of the boot lid.
But it was the insulation tape wrapped round the boot catch as per Mg4nick’s photos above…although I note he didn’t cover the strike surface of the catch.
Many many thanks.
I have the same car and color as you and have the same creak. I will definitely try to tape wrap, thanks for the tip. Regards Barry
    Votes: 934 77.6%
