siteguru
Distinguished Member
- Sep 3, 2022
- Solutions
- 3
- Location
- Strathaven
- MG4 SE SR
I wasn't posting the link to try to "change" anything, nor was I intending to say that anyone was right or wrong.kW is a rate, kWh is a capacity. Battery capacity is measured in kWh, therefore usage of that capacity is also measured in kWh. @Alb is right - and nothing you link to will change that. (And in fact your link simply confirms what we're saying).![]()
Don't worry, someone will always chip in with a comment, that's forums for you.I wasn't posting the link to try to "change" anything, nor was I intending to say that anyone was right or wrong.
That's quite low due to the colder weather, sure you will get a higher rate in summerI seem to be getting 2.48 pedants/thread these days...?! ?
Maybe keyboard warriors can't type properly in cold weather?That's quite low due to the colder weather, sure you will get a higher rate in summer
The 5C number came from anecdotal observations of other brands ... their temperature controls (where numbers are shown) tend to only go up to 27C, but the MG4 (in the app at least) goes up to 32C, hence the 5C difference.
I keep mine at 24C/25C year round.
What is so scary about these figures is when you calculate the equivalent MPG if one is paying the extortionate 'fast charging rate' of 80p/ kwh. Between 2miles/kwh and 2.5miles/kwh your equivalent is between 15MPG and 20MPG. Why fast charging is nearly 3x the cost of the domestic tariff is beyond me, other than greed!I must admit I'm a bit disappointed with the Winter consumption of my MG4.
I was getting over 4 m/kWh in the Summer (using AC when needed) and now I'm getting 2 m/kWh or less (heater set at 25C), that's basically a 50% drop.
With my old 2020 ZS I got around 4 m/kWh in Summer and 2.9 m/kWh in Winter, only a 25% drop.
This is the same journeys, all short and city driving.
The only difference in settings was that I only had to set the heater to 21C in the ZS, but the 25C setting in the 4 is about 5 degrees out so really it's set to 20C.
Bit of greed. Lots of having to recoup the costs of transformers, high voltage lines, the charging points and the ongoing maintenance and ground rent costs.Why fast charging is nearly 3x the cost of the domestic tariff is beyond me, other than greed!
What does your energy consumption screen show for usage. If short journeys & city driving then you would normally use high regen/OPD and this always seems to improve the efficiency. As mentioned in my post today, I got 2.9 in an Xpower for a 105 mile mainly motorway journey with 1 fan speed heating on all the way, but with ECO as part of Custom.I must admit I'm a bit disappointed with the Winter consumption of my MG4.
You mean per miles per kWh. How far you can travel when consuming a given amount of energy.Well, I will leave others to decide whether I meant kwh or kw. The Differences Between kW vs. kWh Explained - EVESCO.
That's because Solo had the balls to take a shorter but more dangerous/difficult route.Maybe you meant Parsecs? There's a chap I know who boasts he can do the Kessel run in less than 12 Parsecs
That's neat. How have you collated the data?Here's my daily consumption rate for about a year
